TomoHawk Posted December 6, 2005 Share Posted December 6, 2005 My 280Z with the original L28 engine has power steering, which uses the parts from a V6 Mustang (rack & pump). I'm wondering about how long is pump will last since the engine turns higher RPMs- usually about 500 - 1000 RPM. On the highway, it's about 3000 - 3500 and could go up to 4500 for sustained peroids (like 90MPH). wil the pump wear out soon, should I have used one from a 4cyl car? thx Quote Link to comment Share on other sites More sharing options...
Cruez Posted December 6, 2005 Share Posted December 6, 2005 You could change out the pulley to get it close as possible to the same operating rpm's. Quote Link to comment Share on other sites More sharing options...
TomoHawk Posted December 6, 2005 Author Share Posted December 6, 2005 So they make a pulley that BIG?? Quote Link to comment Share on other sites More sharing options...
blueovalz Posted December 6, 2005 Share Posted December 6, 2005 Have you compared the diameter of the L6 pulley with that of the Ford crank pulley that was the source of your pump? If the L6 pulley is smaller, good for you, if it was the same size or larger, not so good. Quote Link to comment Share on other sites More sharing options...
