Newbie needs info on head/block compatibility
Guest 280tuz
Hi everyone, just joined this group because I have a 1975 280Z that n42 head has cracked. I used to have a 280ZXT which was totaled in a head on collison. I managed to get the p-90 head and turbo off it. The 1975 has dished pistons. From what I have seen in the internet a p-90 head would bring compression down to 7.4 without the turbo. I am unlikely to put the turbo on this old used motor because of possibly too much stress on the old block and the fact that I would have to re-do the whole exhaust system. I just want to get the old car running well on regular 87 octane gas. I wonder if the compression being at 7.4 would allow me to use cheap gas as well as keeping the same gas milage. I love the car and not interested in racing, just dont want it to be so gutless that I cant keep up with traffic. I also have a n-47 head but unsure of it's condition yet. Also, if the 1975 has dished pistons, does that mean I'ts ok to run a turbo, or what other mods would have to be done to the block. Maybe next summer I will upgrade it with a turbo. Any help I would appreciate. Thanks.
So 7.4 is about what it would be with the existing dished pistons using a p-90 head w/out turbo, sounds like that may not work too good. What do you think about the N-47 head?
Hey J ... I don't know how much you want to get into your engine but I think your best bet for a fun N/A car would be to rebuild your short block with flat top pistons and throw the P90 head on there and from what I've read the P90 head was the best flowing of all the heads. That would give you a CR of 8.52:1 (acording to the L engine calculator). with that compression you would be able to run 87 octain with no problem and still have a "zippy" little car. While you're at it through on a 60mm throttle body(from a 240sx) on instead of the 50mm TB that is on the car now and that should make your car a lot of fun to drive untill you turbo it. If you don't want to rip into the short block then just through the N47 head on there. it'll work great im sure.
rock on Z people :rockon:
