cyrus Posted December 12, 2005 Share Posted December 12, 2005 Hybrid 300ZXTT/Armada R230 Pics Armada case 300ZX LSD Ford Ratech shims 300ZX output shafts Armada 2.96 gears 300ZX input flange My brain sweat Requires reaming LSD bolt holes, and ratech shims as the carries are not offest the same. Quote Link to comment Share on other sites More sharing options...
Cruez Posted December 12, 2005 Share Posted December 12, 2005 pics dead.. looks like a bandwidth issue.. Quote Link to comment Share on other sites More sharing options...
speeder Posted December 12, 2005 Share Posted December 12, 2005 Nice work! I would like to do the opposite - installing Armada 2.96 r&p in a 300ZXTT Diff. Based on your experience, is that possible? Quote Link to comment Share on other sites More sharing options...
cyrus Posted December 12, 2005 Author Share Posted December 12, 2005 That was what I wanted to do but By utlizing the armada case I saved the steps of setting up the pinion. Quote Link to comment Share on other sites More sharing options...
speeder Posted December 13, 2005 Share Posted December 13, 2005 So if I just ream the bolt holes in the ZXTT LSD bigger, use the Armada bolts to attach, then setup the new R&P, it should work in the ZXTT case? For general info, the Armada R&P set is 295.00 list price from Courtesy Nissan's web site. I'm gonna order it very soon, and report results. Quote Link to comment Share on other sites More sharing options...
cyrus Posted December 13, 2005 Author Share Posted December 13, 2005 SPeeder It may work the only thing let is if the pinion interchangeable with each other. I had to shorten the input flange flange around .050" on a lathe also. Quote Link to comment Share on other sites More sharing options...
speeder Posted December 14, 2005 Share Posted December 14, 2005 Thanks Cyrus- Ordered the Armada 2.95 R&P today - will report results. Quote Link to comment Share on other sites More sharing options...
speeder Posted December 21, 2005 Share Posted December 21, 2005 Got the Armada R&P - For info, the ratio is 47/16 = 2.9375. Now to see if it fits in the 300ZX Carrier. To be continued. Quote Link to comment Share on other sites More sharing options...
