Guest jjohart Posted December 17, 2005 Share Posted December 17, 2005 The car=83 280ZXT, custom I/C, DSM BOV, modified POV, 67K miles, Greddy ProB, 18lb flywheel, 3 in exhaust/intake, adjustable FPR (7lbs over stock). The problem-since I had the I/C work put on, whenever the car is in full boost, particularly at hwy. speeds, and I HAVE THE WINDOWS DOWN, even just an inch, I can smell gasoline odors blowing by. Letting off the throttle/boost makes it go away, but it's baaad enuf when my wife notices it! What can I look for, and what can a pro do to isolate it? I haven't been running over 11psi, 14 last summer. I assume it's more difficult than just duct taping everything over! I would bet it'd be much easier to trace if my wife would only stay underhood while I do hwy. boost mode?! Thanks John Quote Link to comment Share on other sites More sharing options...
myplasticegg Posted December 17, 2005 Share Posted December 17, 2005 You're running rich, do you have any way of testing your air/fuel ratio. If you do not, you should. Even a narrow band o2 sensor can be enough to help you figure out your ratio problems. Quote Link to comment Share on other sites More sharing options...
speeder Posted December 17, 2005 Share Posted December 17, 2005 The same thing happened to me once when I had a slight leak in the fuel rail/injector hoses. Only the higher fuel pressure under boost would cause it to leak enough to be noticed. Quote Link to comment Share on other sites More sharing options...
Guest Loose_Screws Posted December 17, 2005 Share Posted December 17, 2005 The same thing happened to me once when I had a slight leak in the fuel rail/injector hoses. Only the higher fuel pressure under boost would cause it to leak enough to be noticed. Yep! Check your injector hoses or if you have o-ring setup, check those. Do you have a FP gauge? You could actually be running too much fuel pressure under boost and getting waaayyy too much fuel. Quote Link to comment Share on other sites More sharing options...
dapiper Posted December 18, 2005 Share Posted December 18, 2005 Also consider exh leak and rich. Quote Link to comment Share on other sites More sharing options...
iaconsultants Posted December 18, 2005 Share Posted December 18, 2005 Is the smell like gasoline from a gas pump or does it have a slightly different smell to it. Or third does it have a distinct burned smell to it. The first smell I would say fuel rails or fuel lines. The last would most likely be an exhaust leak probably manifold. The middle one could be a bit more tricky - head gasket streched, intake manifold leak, etc. You might be able to detect some of it by looking for fuel stains along your engine or engine bay. You could also take a small rubber hose and put one end near your hear and move the other end around your engine (while its running) to see if you hear any sucking noises (yes you can by a car stehtascope which is better and a good tool to have). If you do that is where you have a leak and under boost it would blow out not suck in. Hope that helps Robert Quote Link to comment Share on other sites More sharing options...
