BWRex Posted December 24, 2005 Share Posted December 24, 2005 Thought I'd share my early Christmas gift Quote Link to comment Share on other sites More sharing options...
tec280zx Posted December 24, 2005 Share Posted December 24, 2005 Sweet, mine came early too. Too bad santa sent the wrong sizes. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted December 24, 2005 Share Posted December 24, 2005 who made those tension rods? mike Quote Link to comment Share on other sites More sharing options...
260DET Posted December 24, 2005 Share Posted December 24, 2005 So whats wrong with the wheels, not wide enough Use one to stand your Xmas tree in Quote Link to comment Share on other sites More sharing options...
240hoke Posted December 24, 2005 Share Posted December 24, 2005 Sweet! Glad to see you put those parts to use, they looks great! i like your u bracket better then mine, did you have the width custom bent? heres my link one these arms: http://www.geocities.com/projectzt/tcrod.html Quote Link to comment Share on other sites More sharing options...
BWRex Posted December 24, 2005 Author Share Posted December 24, 2005 I used 240hoke's design,and fabbed the feet roaching out 2 $$ drill bits and a couple few grinding wheels.That 3/8 cold rolled steel is some strong stuff!I just took 2in.x10inx3/8 cold rolled steel,cut it in half,drilled the holes,cut out one,and used it as the template for the other.The T/C's are twice as heavy,and 3x beefier than the stock ones easily.I should leave Santa some cookies and a six-pack,and maybe they'll be installed Christmas morning.... Quote Link to comment Share on other sites More sharing options...
BWRex Posted December 24, 2005 Author Share Posted December 24, 2005 Thanks again Austin! Quote Link to comment Share on other sites More sharing options...
BWRex Posted December 24, 2005 Author Share Posted December 24, 2005 Actually I got the u bracket from chassisshop.com,I had to enlarge the side holes to accomodate the 5/8 bolt.The width was dead on with a couple of hardened 5/8 washers for spacers in between.Couldn't have worked out any better.I do have a question however about the adj. lower control arm spacers.Isn't one longer than the other to center the wheel in the wheelwell?Any crossmember bushing mesurements would be appreciated. Quote Link to comment Share on other sites More sharing options...
240hoke Posted December 24, 2005 Share Posted December 24, 2005 I can get a good mesaurement on those LCA bushing next week, Im getting my car up on the alignment rack and will have to pull the bolt to adjust them so i can measure then. However, I just measured off the stock bushing so you sound be able to figure it out. Quote Link to comment Share on other sites More sharing options...
BWRex Posted December 24, 2005 Author Share Posted December 24, 2005 yea it shouldn't be too difficult.Are you going to get them machined?I wonder if there would be an extra set laying around when you finish with your calculations.........Lol!Let me know how they turn out.I was thinking aluminum,2 piece,2 'stepped',Inner dia.whatever the Outer dia.of the sleeve is,Outer dia 5/8 for insertion into the heim,stepping up a larger size to hold it in place.Obviously each side would be of different lengths,just a thought. Quote Link to comment Share on other sites More sharing options...
