Mike Rowe Posted January 5, 2006 Share Posted January 5, 2006 Hi guys, I want to fit a remote oil filter to my RB motor when fitted to my 240Z - has anyone done this and/or does anyone know where I can get one. I used a remote set up and oil cooler on my V8 MGB so want to do similar on the Z - can anyone help? regards Mike Quote Link to comment Share on other sites More sharing options...
260DET Posted January 5, 2006 Share Posted January 5, 2006 Think you'll find that a Chev setup will fit, just check the thread sizes to make sure. I got my spin on oil cooler adaptor from here, very good service http://www.thinkauto.com/ Quote Link to comment Share on other sites More sharing options...
PeterZ Posted January 5, 2006 Share Posted January 5, 2006 I think the oil filter for a Z is the same as for a Ford engine (Fram PH8A) so the adapter will need to match the engine threads (verify per 260DET), the remote filter can be whatever you choose. Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted January 5, 2006 Author Share Posted January 5, 2006 Richard thanks very much. Had a look at your site, excellent, car looks great. The half roll cage looks a good design - did you make it or purchase it? Does it meet CAMS regs? Is it Chrome molly? regards Mike Quote Link to comment Share on other sites More sharing options...
260DET Posted January 6, 2006 Share Posted January 6, 2006 The half cage is made from cold drawn steel, it was designed to provide some rollover and side protection but designed mainly to stiffen up the rear of the body and so improve handling. CAMS have gone all stupid, they only approve FIA compliant full cages now but I don't compete in events which require an approved cage anyway. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 6, 2006 Share Posted January 6, 2006 Use an adapter made for a Ford. I have a Hayden on my motor and it threaded right on. Any of the universal kits have the correct fittings. My beef with the universal kits(available from Summit or Jegs) is the lines are too small. I chose to get one with 1/2" NPT fittings and am plubming it with -12AN lines. I believe Joel ended up with the same one I did. Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted January 6, 2006 Author Share Posted January 6, 2006 260DET said: The half cage is made from cold drawn steel, it was designed to provide some rollover and side protection but designed mainly to stiffen up the rear of the body and so improve handling. CAMS have gone all stupid, they only approve FIA compliant full cages now but I don't compete in events which require an approved cage anyway. I agree with you CAMS are a pain in the A, can never keep up with the changes. As long as you can compete thats greta, thanks Mike Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted January 6, 2006 Author Share Posted January 6, 2006 JAMIE T said: Use an adapter made for a Ford. I have a Hayden on my motor and it threaded right on. Any of the universal kits have the correct fittings. My beef with the universal kits(available from Summit or Jegs) is the lines are too small. I chose to get one with 1/2" NPT fittings and am plubming it with -12AN lines. I believe Joel ended up with the same one I did. Thanks Jamie, will check it out Mike Quote Link to comment Share on other sites More sharing options...
