Stock Gauge size in dash
Wide260z
Did anyone notice the new Autometer Phantom II's and Sport-Comp II's. They look nice with the through dial lighting! Unfortunately, they are only available in 2 1/16" "with no plans to produce the 2 5/8"", I emailed them yesterday. They should be releasing the 5" Speedo and Tach in Spring 2007!
Does anyone know where I can get some similar gauges in the sizes we need? I have looked at VDO, Nordskog, Autometer, Stewart Warner, and Speedhut.
Thanks,
Joshua
hey i found some really nice 60mm gauges is there anyway to make them work though? I want to replace my clock wiht a boost gauge
I suppose you could but, you would have to fabricate bezel ring to make up the difference. (2.625" [66.68mm] minus 2.362" [60mm] divided by 2 equals 0.132" [3.35mm]) 0.132" would be the cross-section of the bezel. Gotta lathe?
