got a new commuter, 90 eagle talon tsi
mobythevan
MSnS is what I'm thinking around summer time. Get it running first and drive it a little.
I didn't realize he had purchased all of this stuff and didn't install it. It comes with the following parts:
already installed:
EVO III 16G turbo
EVO III exhaust manifold
Walbro 255 fuel pump
not installed yet:
nice brand new 3" intercooler
boost controller and install kit
re-wire kit for fuel pump to boost voltage
K&N filter and 3" intake kit
boost gauge and pod mount
ball bearing shifter kit
K&N valve cover breather filter
All the goodies to hit the pavement with 300hp I'm thinking.
thats a mid 12sec car right there..
i had 2 1st gen AWD DSM's.
with a mild 16G, reg tires on stock wheels, boost at 19psi, fuel pump, 2 stock 3000GT VR4 intercoolers, crushed bov and dumped exhaust i was running 12.3's all day long on 93pump.
ppl have done that with the stock 14B turbo too..
i also had a 20G turbo DSM.. the 16G would romp it on the street!
have fun with that sucker!
mike
stock ecu.. i forget on injectors but there pretty big.. i think 450cc.
i remember having 720cc's on the 20G.. i just forget on the 16G gsx.... i think stock.
i think i had all fuel supported parts but stock injectors..
mike
Guest strokerZ
There are some very fast Talons running around the streets here...Check out the Talon (2.4 stroker)that was built at the shop where I go for tuning. There are a few videos as well.
tappauto.com
729 RWHP
9.89 at 145mph
This is a daily driven street car.
Its going to be a couple weeks before it hits the road. The timing belt was loose and it slipped so the valves are bent. I got it pulled down to the belt tonight and confirmed, I can slip the belt around the crank gear by hand, its that loose. Rockers are also way loose on the intake so the valves are toast. If the pistons are good and the head can be rebuilt it will be back up in no time. I needed something to keep things from getting boring, ugh......
