l28et + 240z tranny?
jimbo5670
I guess my link didn't work. Here's the deal. The 240 came with the weakest pressure plate. The 260 and 280Z came with a stronger pressure plate. If you have an aftermarket 240 pp they are usually the same as the 260 and 280. IME they'll hold down about 200 whp, at which point they start to slip really bad in the higher gears. Put ~250 whp to one and you basically have no ability to launch the car anymore. Mine wouldn't even move. Just sat there burning the clutch. It will also slip for 2-3 seconds between shifts.
My ACT pp is holding down my ~240ish whp now just fine, but the stock pp wouldn't do it.
If you want to use that flywheel you'll need an aftermarket pp. If not, you'll need a turbo flywheel and a turbo pp with the larger diameter disk. IF YOU SWAP THE CLUTCH YOU NEED THE APPROPRIATE THROWOUT BEARING COLLAR TO GO WITH IT.
Even though my link didn't work you can SEARCH "l28 l24 clutch" and you will come up with the same very relevant links that I tried to get you to in the first place, and they will have more info and insight about your question.
