280Z axle bolt
Guest 73LT1Z
I searched this forum for bolt & didn't find an answer...
I'm doing a rear disk conversion & found I'm missing two of four special shoulder bolts that hold the outer u-joint on the rear axle on my '75 280. I've attached a pic. I need to find the part # for these 10mm bolts.
TIA
My Nissan Fast program doesn't go back that far, but I'm sure if you called the dealer, that is a readily available part.
