mobythevan Posted January 19, 2006 Share Posted January 19, 2006 If threads strike you as must read or sticky type please PM me and I will add them in here to consildate. I did this to keep from getting too many stickies because there are so many good posts. Must Read Threads LS1 MSnS install notes http://forums.hybridz.org/showthread.php?t=122976 MSII on NA 78 280z with stock wiring http://forums.hybridz.org/showthread.php?t=113860 V3 EDIS http://forums.hybridz.org/showthread.php?t=103781 Correct EDIS 6 wiring http://forums.hybridz.org/showthread.php?t=122394 Distributor-LESS ignition writeup by BRAAP http://forums.hybridz.org/showthread.php?t=113165 My notes for 83zxt to MSnS-e on v3 PCB (PWM and VB921) http://forums.hybridz.org/showthread.php?t=107106 Anyone want MegaSquirt but no laptop?! Here's my PDA setup.. haha i love it http://forums.hybridz.org/showthread.php?t=102322 Adding Boost Control http://forums.hybridz.org/showthread.php?t=101073 hall switches for MS&S-extra trigger http://forums.hybridz.org/showthread.php?t=98835 TPI MSnS install notes http://forums.hybridz.org/showthread.php?t=101901 old stuff, some interesting some not Since the MS section is new I decided to provide links to older MS threads that are spread all over the Hybridz site. Maybe save some people time searching and weed out some of the easy questions. MS with MSD http://forums.hybridz.org/showthread.php?t=95210 MS with supercharger http://forums.hybridz.org/showthread.php?t=95408 http://forums.hybridz.org/showthread.php?t=93896 http://forums.hybridz.org/showthread.php?t=93600 http://forums.hybridz.org/showthread.php?t=93091 Where to buy MS already assembled http://forums.hybridz.org/showthread.php?t=93493 http://forums.hybridz.org/showthread.php?t=91207 MS Settings http://forums.hybridz.org/showthread.php?t=91962 http://forums.hybridz.org/showthread.php?t=91006 Precision Wideband from B&G http://forums.hybridz.org/showthread.php?t=91040 MS Pricing http://forums.hybridz.org/showthread.php?t=88314 Link to comment Share on other sites More sharing options...
v8260 Posted March 13, 2006 Share Posted March 13, 2006 these are good ones too Megasquirt forum http://www.msefi.com/ The Megasquirt site http://www.megasquirt.info Link to comment Share on other sites More sharing options...
Guest 1seymour Posted June 17, 2006 Share Posted June 17, 2006 can you change "My notes for 83zxt to MSnS-e on v3 PCB (Hall and VB921)" to: "My notes for 83zxt to MSnS-e on v3 PCB (PWM and VB921)" i think it's more relevent that way.. i had originally confused opto with hall and am not sure if i can change the title of the original post or not. Link to comment Share on other sites More sharing options...
hoohaa Posted July 9, 2007 Share Posted July 9, 2007 I just ran across this thread: http://www.msextra.com/viewtopic.php?t=24702 GREAT info on the Nissan CAS distributor and MegaSquirt settings. You must be a forum member and logged in to view the files. I have them archived if they are ever taken down. Link to comment Share on other sites More sharing options...
SleeperZ Posted April 20, 2012 Share Posted April 20, 2012 On 7/9/2007 at 9:03 PM, hoohaa said: I just ran across this thread: http://www.msextra.com/viewtopic.php?t=24702 GREAT info on the Nissan CAS distributor and MegaSquirt settings. You must be a forum member and logged in to view the files. I have them archived if they are ever taken down. They seem to be taken down. Link to comment Share on other sites More sharing options...
