Mike Rowe Posted January 22, 2006 Share Posted January 22, 2006 Anyone done this - when you change to rear pan sump the dipstick will have to be moved and presumably a new hole drilled. I notice a slight indentation on the block that may be able to be drilled out. If you've done it were you successful at getting the dipstick tube ourt and reusing - any tips? How did you go about drilling out the back and plugging the original location? thanks Mike Quote Link to comment Share on other sites More sharing options...
kcelectronics Posted January 22, 2006 Share Posted January 22, 2006 My understanding is thet it is already there with a brass plug in it, you just knock it out and swap it over with the dipstick? Check this thred. Dipstick Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted January 23, 2006 Author Share Posted January 23, 2006 thanks Chuckie, read the thread - fantastic, just what I wanted regards Mike Quote Link to comment Share on other sites More sharing options...
KAZU Posted January 30, 2006 Share Posted January 30, 2006 Mine doesn't have rear dipstick hole. The block is 24U from R32 GT-R. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted January 30, 2006 Share Posted January 30, 2006 Quote My understanding is thet it is already there with a brass plug in it' date=' you just knock it out and swap it over with the dipstick? Check this thred. Dipstick Yea Mike, don't be a dipstick! Sorry, I couldn't resist the opportunity:) Quote Link to comment Share on other sites More sharing options...
cheftrd Posted January 30, 2006 Share Posted January 30, 2006 KAZU said: Mine doesn't have rear dipstick hole. The block is 24U from R32 GT-R. The 26 blocks are mostly not drilled. There is a boss for where the dipstick is supposed to go. You will have to drill it yourself. Outside Inside Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 31, 2006 Share Posted January 31, 2006 The one I got from Stony was obviously done already, but the one I bought off Ebay had a plug in the rear location. R32, I don't remember the block numbers. Quote Link to comment Share on other sites More sharing options...
KAZU Posted January 31, 2006 Share Posted January 31, 2006 Quote The 26 blocks are mostly not drilled. There is a boss for where the dipstick is supposed to go. You will have to drill it yourself. Thank you for the input. I'm considering drysump, btw. Quote Link to comment Share on other sites More sharing options...
GTR-240Z Posted January 31, 2006 Share Posted January 31, 2006 My block is suppose to have come from a R33 and it does not have a hole at the back either. I'm the same as Kazu currently looking into dry sumping it. Oh well more money to spend on my project. Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted February 5, 2006 Author Share Posted February 5, 2006 I've just done mine this morning and it is a breeze. My block is an R32 GTR and it has the brass welch plug in the back. Popped it out from the sump side with an 8mm drift, then started the Diptick tube from underneath with a 10mm drift, followed by the 8mm drift again to get it out all the way. Then simply put the brass plug in the front with a bit of sealant. Took all of 5mins. Incidentally the back hole is marked with a 2 next to it and the front one with a 1 Quote Link to comment Share on other sites More sharing options...
Ed260Z Posted February 6, 2006 Share Posted February 6, 2006 I looks like I might be getting an R34 block which means that it probably won't have a plug for the rear dip stick. Is this something that I can do with a hand drill, or should I take it to a Machine shop? Quote Link to comment Share on other sites More sharing options...
