300zxRB26 Posted January 28, 2006 Share Posted January 28, 2006 Ok guys i had posted once before about failing my emissions with my 1988 300zx turbo. Let me give u some background i bought the car for $1100 in excellent condition except i needed a new clutch, turbo, steering rack, and some small other things. I took the car through emissions the first time and failed for NOx with these numbers... Standard Reading NOx 1184 2198 HC 157 109 CO% .88 .30 CO2% 13.3 O2% 1.2 So I went home and worked on it some and cleaned my egr valve and ran it through again and failed for NOx with these numbers Standard Reading NOx 1184 1645 HC 157 99 CO% .88 .81 CO2% 14 O2% 1.0 So for the third time i took it home and replaced my pcv valve, did a cap ,rotor, wires, changed the oil, new air filter, cleaned my injectors, and had a small exhaust leak, before the cat, fixed...but now i failed for both hydrocarbons and NOx with these numbers... Standard Reading NOx 1184 2197 HC 157 224 CO% .88 .88 CO2% 13.2 O2% 1.2 whats goin on here? what are your ideas on what i should do?...i have four days till my registration is suspended so help me out quick...thanks guys Quote Link to comment Share on other sites More sharing options...
300zxRB26 Posted January 29, 2006 Author Share Posted January 29, 2006 is anyone gonna help me out with this? Quote Link to comment Share on other sites More sharing options...
WolF Posted January 29, 2006 Share Posted January 29, 2006 Have you changed your spark plugs yet? Try checking your spark plugs and also make sure that you have the correct gap. I also suggest that make sure that your timing is correct. After all this then go to Pepboys and buy the additive for the fuel thats suppose to help you pass smog, I forget the name. Your suppost to fill up full tank and put the additive in, recomend half tank and the additive. I had the same problem with my eclipse after I did all the after market mods it was really hard getting it to pass smog, thats why I sold the peice of junk . Well try those thing first any questions just email me and ask. I'll think of something. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted January 29, 2006 Share Posted January 29, 2006 I am only guessing on this one but you might need a new cat or 02 sensor. They do not last forever. I would have someone look at those numbers an give you an estimate on what it would take to fix it and go from there. Quote Link to comment Share on other sites More sharing options...
300zxRB26 Posted January 29, 2006 Author Share Posted January 29, 2006 Well i already changed the plugs, and when i took it in to get the exhuast done, they told me that the cat wasn't bad. NOw i told them it was and they didn't believe me, and today i took it back and it turns out my cat is bad. Now for my O2 sensor it was already replaced. I'm just gonna take it to a private inspector and buy a sticker and be done with it, becuase im gonna have to do that when i put the rb26 in it (i cant wait). thanks for your help though Quote Link to comment Share on other sites More sharing options...
WolF Posted January 29, 2006 Share Posted January 29, 2006 Well i already changed the plugs, and when i took it in to get the exhuast done, they told me that the cat wasn't bad. NOw i told them it was and they didn't believe me, and today i took it back and it turns out my cat is bad. Now for my O2 sensor it was already replaced. I'm just gonna take it to a private inspector and buy a sticker and be done with it, becuase im gonna have to do that when i put the rb26 in it (i cant wait). thanks for your help though Ok Good luck with the swap. Quote Link to comment Share on other sites More sharing options...
