nazar Posted January 30, 2006 Share Posted January 30, 2006 Can I really use the DAT106 jtr mount? Some say yes, some say no, JTR says probably not If i fabricate my own, what is the best thing to attach it to? Should it bolt in, or weld in? (the only thing i would be willing to make is a straight style crossmember) Do I tie it to the frame rails? What does the jtr mount tie to? I put a urathane tranny mount on the t56 with the 2 studs coming out. Gotta get something by the end of the week to get that sucker in there. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted January 31, 2006 Share Posted January 31, 2006 I used it when I did the same swap. You will need to redrill the hole for the tranny mount and use a couple of flat washers to to fine tune the u-joint alignment but I had no problems. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 31, 2006 Share Posted January 31, 2006 I thought MikeJTR said in one post that a T56 cross member can be made out of a flat piece of stock since the T56 mount comes down about an inch farther than the T5 setup. It was in a post where some guy mounted his JTR supplied cross member upside down to get it to work. Quote Link to comment Share on other sites More sharing options...
Bartman Posted January 31, 2006 Share Posted January 31, 2006 Here's a thread where MikeJTR talks about what he recommends for installing a T56 in a Z. http://forums.hybridz.org/showthread.php?t=94584 Quote Link to comment Share on other sites More sharing options...
