Cams from R26DETT into RB25DET ?
turbo_fb
The RB25DET uses hydraulic lifters versus the RB26DETT using solid lifters. It's kind of like P90A vs. P90 heads on the L-Series.
Tomei does make a kit to convert the RB25DET lifters to solid believe it or not.
http://www.rbmotoring.com/catalog/product_info.php?products_id=934
But to answer your question, RB26DETT camshafts will not work on a RB25DET application.
Does anyone know the base circle difference in the two cams? In the VW/Audi world you can have the solid lifter cams (larger base circle) reground to be uses in a hydro lifter (smaller base circle) head. This makes it possible to have a bigger cam/s reground without having to add material to them.
Just a looming question from the back of my mind.
Later
Kenny
Later
Kenny
Isn't most of the Eurospec/DTM stuff totally different from the JDM designs to begin with?
