SPOT WELD FIX
Hey guys, I pulled my motor and tranny yesterday and totally stripped the paint out of the engine compartment. Question is would I be wise to weld all the seams that are spot welded? It seem that this would be
good for stiffening up the chassis but
may cause some warping. I also plan on
re-routing the wiring harnes to the outside of the engine compartment to keep it away
from the exhaust.. What do you think?
Myron
Myron,
I'd definately weld all the seams but if you do it right there will be little to no warpage. Space spot welds about 1" apart. Do this all along the weld line and then fill inbetween the welds you made with another set of spot welds. Keep on doing this until it looks like a solid weld. This will prevent excess heat buildup and you can keep things from getting buggered up.
SpencZ
Depending on your welder, you might be able to dial in a fine tuned range and run seem welds. I'd run spots about six inches apart and then run the seem between the two spots. DO NOT CRANK THE HEAT UP. If you have access to a 220 Welder you will get a much better dial in for heat and get a more consistant weld.
Mike
mjk
My personal welder is just a little 110 wire feed. My neighbor is going to let me use his
big nasty proffesional grade mig that runs
on 220 up to 480 and will feed some really thick wire, he has a full bottle of argon
and it is ready to rumble. I just have to go load it on a trailor and drag it over to my house. I have been filling in all of the little holes in the engine compartment and
plan on doing the floorboard this weekend.
