Synlubes Posted February 13, 2006 Share Posted February 13, 2006 After many years of working in a cold unheated garage and out on the driveway in winter, I broke down and bought a heater. A 55,000 btu kerosene forced air Reddy Heater. The temp here today was 40 degrees outside and 54 in my garage. My garage is 14’ x 24’ with a 12 foot ceiling, after only 15 minutes the temp in the garage was 70 degrees. I have a vented hatch to my overhead for the garage so fumes are not an issue for me. There really wasn’t a problem with fumes while the heater ran, just when starting and shut down. The heater is much more than I need for inside, but will also suit me well when working on the drive in the cold. Lowes has them now for $99.00 down from $199.00 (closeout). Some of the best money I’ve spent in a while! Quote Link to comment Share on other sites More sharing options...
Some-Guy Posted February 13, 2006 Share Posted February 13, 2006 ill have to check it out my garage is unheated no insulation well actualy its a barn lol it doesnt even have doors on the ends but i got a few enclosed rooms ill have to check into getting one of those Quote Link to comment Share on other sites More sharing options...
pparaska Posted February 14, 2006 Share Posted February 14, 2006 My garage is part of the house - the master bedroom is right above it. I don't like this layout, as it's unsafe. If I burn the garage down, there goes the house! Also, fumes get into the house from the garage, no matter how well I've sealed things up - going in to use the facilities is an issue. Anyway, for this reason, I wanted to do something both more capable for heat output and with less/no fumes than the old Kerosun kerosene heater. I looked at propane heaters, but the deal with having to refill, the possible fire hazard and fumes kept me away. I found a great solution, for me anyway. A 230V 20.2AMP electric "construction site" heater. It can warm the 25x20x9' garage from 50 to 65 in about 1/2 hour. Fairly quiet, and has a thermostat. I'm very happy with it, and would suggest it as an alternative to burning fuels in the garage. Here's a link to the place I bought it: http://www.shopfnc.com/qmbrh402.htm I bought the BRH562. (note that the above site has the voltage switched in the specs, here are the correct specs): Model#_Volts__Watts_______BTU/HR____Amps BRH562_240/208_5600/4200_19,110/14,33_23.3 / 20.2 19,110 BTU/HR is fine for a typical 2-car garage, IMO. If I'm out in the garage for 8 hours on a 30s-40s day outside, it takes about 30-45 minutes to get into the 60s from about the high 40s, and then only comes on maybe 10-20% of the rest of the time. That's like 15-20 kWh, which on my "off-peak, non-summer" rate (currently 0.03252 $/kWh) is about 50 to 65 cents for the whole day! Even if it stayed on the whole 8 hr stint, it'd be $1.45. Quote Link to comment Share on other sites More sharing options...
