300GTE Posted February 15, 2006 Share Posted February 15, 2006 help, i have an 86 300zx na, with a no start condition, the engine rotates fine , when the key is turned to start but, but engine makes no attempt to run for any length of time. the engine has had a full yune up today, spark plugs, wires, cap and rotor, and coil are all new. any helpful info would be appreciated. Quote Link to comment Share on other sites More sharing options...
BrandonsZ Posted February 15, 2006 Share Posted February 15, 2006 Did it start before the tuneup? Quote Link to comment Share on other sites More sharing options...
Guest wearedriven Posted February 15, 2006 Share Posted February 15, 2006 maybe the timing belt broke open the oil filler cap crank have some one crank it and lokk to see if the rocker arms move Quote Link to comment Share on other sites More sharing options...
300GTE Posted February 15, 2006 Author Share Posted February 15, 2006 BrandonsZ said: Did it start before the tuneup? I just bought it and it wasnt running due to an accident the cap and rotor was smashed by the hood. Quote Link to comment Share on other sites More sharing options...
300GTE Posted February 15, 2006 Author Share Posted February 15, 2006 Is the oil pump driven by the timing belt? I asked this because, the oil pressure gauge shows no oil pressure while trying to crank the engine. Quote Link to comment Share on other sites More sharing options...
Jonas240z Posted February 16, 2006 Share Posted February 16, 2006 Dumb question but...have you cheked the oil level, if there's no oil pressure the computer won't let you start the car up (At least that's what my dad's car did one day). Also double check the wire placement and plug gaps. Check for spark at the plugs and fuel pressure. Good luck! Quote Link to comment Share on other sites More sharing options...
300GTE Posted February 20, 2006 Author Share Posted February 20, 2006 Jonas240z said: Dumb question but...have you cheked the oil level, if there's no oil pressure the computer won't let you start the car up (At least that's what my dad's car did one day). Also double check the wire placement and plug gaps. Check for spark at the plugs and fuel pressure. Good luck! my oil level was full the oil actually is quite clean. Quote Link to comment Share on other sites More sharing options...
300GTE Posted February 20, 2006 Author Share Posted February 20, 2006 wearedriven said: maybe the timing belt broke open the oil filler cap crank have some one crank it and lokk to see if the rocker arms move i think you were right there is no movement inside the valve cover. Quote Link to comment Share on other sites More sharing options...
Cable Posted October 11, 2007 Share Posted October 11, 2007 Alot of times with electric oil pressure senders/gauges the gauge will not show any pressure during cranking due to all power being directed at the starter and ignition/EFI. Do you have spark? Does the ECU work? Checked all your fuses? Quote Link to comment Share on other sites More sharing options...
Tombarace14 Posted October 11, 2007 Share Posted October 11, 2007 bringin back an old thread arnt ya BBZ. He stated that the cams wernt turning (broken t-belt). Quote Link to comment Share on other sites More sharing options...
