Guest Frank280z Posted May 27, 2000 Share Posted May 27, 2000 I just got Suspension Techniques 1" drop springs and Tokico twin tube struts. Almost ready to install. Waiting on my mounting kits. Will I be able clear a set of 16x8s with 225 50s? Or will I be better off with a 15" rim with the 225 50s? Frank280z Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 28, 2000 Share Posted May 28, 2000 Hi Frank, With the right offset on the wheels the 16's should work good. You might even be able to go with a little larger tire. The 225/5016's are the same hieght as the stock 195/7014's. The're also the same hieght as the 225/6014's I using on my 73. They will rub in the front, but an aftermarket airdam will add plenty of room. I wouldn't go any wider than 7 inches with the 225's. For that size tire its the ideal width. I sell tires & service for a living. I know tires but I don't know much about wheel offsets. However the JTR manual covers tire size & wheel offsets. Glenn Quote Link to comment Share on other sites More sharing options...
Mikelly Posted May 30, 2000 Share Posted May 30, 2000 Frank, you want Zero offset on that car. The hubs, and bearings were designed for zero offset from the factory and anything over 1/2 inch deviation will cause premature wear on tie rods, ball joints and bearings! Also 225/50-16s should clear... might have to grind off the outside edge to the spring perch, but that isn't a big deal and won't hurt anything... just make sure it doesn't rub! Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
