Guest Anonymous Posted June 19, 2000 Share Posted June 19, 2000 83 280ZX Non-Turbo. The front end is shakeing a hole lot and frankly its alittle scary sometimes. mostly under brakeing, stearing wheel and all. its also pulling to the left a bit. Help Me, DannyZ ------------------ Quote Link to comment Share on other sites More sharing options...
Mikelly Posted June 19, 2000 Share Posted June 19, 2000 Sounds like bad rotors if it only on braking....check you wheel bearings and ball joints... then check your tie rods as well. Don't ignore that one.... Bad bad bad! Mike ------------------ "I will not be a spectator in the sport of life!" mjk Quote Link to comment Share on other sites More sharing options...
John Scott Posted June 19, 2000 Share Posted June 19, 2000 Also check your tension rods, steering rack, struts, anything and everything you can get your wrenches on. YIKES! JS [This message has been edited by John Scott (edited June 19, 2000).] Quote Link to comment Share on other sites More sharing options...
