Car wont do anything
Remove the positive battery post and clean them really good. Spray it with a corrosion protective coat and put it back and you should be on your way. I've been having this same problems on my 2 ZXs and it was the battery posts being dirty/corroded. You can't really see the corrosion but it is there. Just get the wire brush clean the post and it's back to normal.GL
Ther are 3 large multi wire connecter's under the dash where the engine compartment main wiring harness goes threw the fire wall and connects up high to the dash harness, behind the glove box. Also check to see if the main ground connection, located on the passenger side front frame rail , under the battery tray, is not corroded .
