pparaska Posted August 20, 2000 Share Posted August 20, 2000 I'm pretty sure they are the same halfshafts and u-joints between the R180 and R200. Just be sure that the u-joints haven't been replaced with the kind with the threaded hole in the cross between two adjacent trunion caps for a grease fitting. Quote Link to comment Share on other sites More sharing options...
MYRON Posted August 20, 2000 Author Share Posted August 20, 2000 Well, I finally shattered the ujoints on my car! I bought a g-tech pro and started to fine tune my car. After playing with the 0-60 times and adjusting the jetting and timing I trimmed 6/10ths of the time. On the last run, I launched then hit 2nd and all hell broke loose! My question is- Are the stub axles and ujoints the same in the r180 and r200? I have a 78 parts car that still has the axles and diff. (r-180) will it work???? Myron Quote Link to comment Share on other sites More sharing options...
MYRON Posted August 20, 2000 Author Share Posted August 20, 2000 I have decided to take the axles to the guy who did my driveshaft and see if he can put me some heavy duty ujoints in it.. I do not want to go through the whole process of using used parts in it again, there is no telling how long they will last... Myron Quote Link to comment Share on other sites More sharing options...
PaulR Posted August 21, 2000 Share Posted August 21, 2000 I'm curious, what kind of 0-60 times were you getting? I've been getting around 4.6 sec measure with my G-Tech. BTW, 6/10 is quite an improvement! quote: Originally posted by MYRON: I bought a g-tech pro and started to fine tune my car. After playing with the 0-60 times and adjusting the jetting and timing I trimmed 6/10ths of the time. Quote Link to comment Share on other sites More sharing options...
MYRON Posted August 21, 2000 Author Share Posted August 21, 2000 I got a 4.51 and then on the second test run BANG!! no more ujoints when i hit second gear! Myron Quote Link to comment Share on other sites More sharing options...
PaulR Posted August 22, 2000 Share Posted August 22, 2000 OK, just saw the 0-60 posts in the "I'm tellin' ya" forum. 4.51 sec is pretty impresive! Quote Link to comment Share on other sites More sharing options...
MYRON Posted August 22, 2000 Author Share Posted August 22, 2000 I'm pretty happy with it. I think if i can get it tuned right I will be able to get it in the low 4's or even high 3's... It has a bad hesitation when you punch it, then it doesnt pull hard from 5-6k.... Quote Link to comment Share on other sites More sharing options...
