oil pressure
Guest tom1982zx
  • 1 month later...
I've had 4 L6 Z-cars. Every one idled at indicated pressure that's quite low (20 PSI or less), and runs in the 50-60 PSI range at road speed. As noted above, oil pressure sending units in these have a high failure rate, so if your readings are odd, replace the sending unit. It takes about 5 minutes to change them.:cool:
