2.0mm or 1.0mm For My Head Gasket - L28ET
slownrusty
Guys - I am just in the process of rounding up the last of the parts I need for my L28ET build-up...for the Metal Head Gasket...do you recommend 1.0mm or 2.0mm and where did you guys buy your MHG?
I will be running 15-18psi on the street.
Thanks!
Yasin
Guest ON3GO
Make sure to check the holes in the gasket vs the head and block. I bought one once and it was wrong. Not saying they all are just be sure and check.
Good luck and can't wait to hear more about the buildup!
ya i had the same problem and i ran the engine like that for along time..
took it apart and saw the problem. never overheated or anything so i dunno....
mike
