Z24O Posted April 28, 2006 Share Posted April 28, 2006 hi guys, anyone got any advice on which roots/screw superchargers will fit on an 86-93 302 windsor? it seems you can get the eaton 112 s/c fairly cheaply secondhand with low mileage,few kenne bells and whipple/opcons on e-bay as well but the intake manifold sems to be the stumbling block in most cases...was wondering if anyone's adapted anything to fit any info appreciated regards paul ps not really interested in fitting a centrifugal s/c until i've exhausted other options.....also have EMS capable of running crank angle sensor instead of distributor(as it's in the wrong spot for most of the above options) Quote Link to comment Share on other sites More sharing options...
Z24O Posted April 28, 2006 Author Share Posted April 28, 2006 bump Quote Link to comment Share on other sites More sharing options...
s3079893 Posted May 1, 2006 Share Posted May 1, 2006 I know a guy running a 400hp 302 clevland with a paxton cetrifugal supercharger, but thats about it. Y dont u want centrifugal? Quote Link to comment Share on other sites More sharing options...
Z24O Posted May 11, 2006 Author Share Posted May 11, 2006 don't want centrifugal because i want off idle instant torque....otherwise might as well use a turbo regards paul "just say no to lag" Quote Link to comment Share on other sites More sharing options...
s3079893 Posted May 11, 2006 Share Posted May 11, 2006 is peak power important, if not you could use a small turbo Quote Link to comment Share on other sites More sharing options...
Z24O Posted May 16, 2006 Author Share Posted May 16, 2006 g'day S30.... after exhausting my search for a blower for a windsor it looks like i will be going twin turbo...probably a couple of r33 skyline turbos off the rb25DET motor...........i am also thinking of LPG so that i can raise the compression ratio to assist with off boost(low rev) torque let me know if you have any input thanks paul Quote Link to comment Share on other sites More sharing options...
s3079893 Posted May 16, 2006 Share Posted May 16, 2006 yeah that seems like a good way to go. Im building a 5L NA windsor and im also planning to go strait gas. I'm thinking of either using an impco 450 carb or a twin throttle boddie gas research carb (but that company is hard to get hold of). Are you planning on running a manual or auto, i hear that manuals have a problem with backfireing which isn't so bad for me because im running normally asperated, but if your running turbos this could cause a problem Quote Link to comment Share on other sites More sharing options...
LMoore56 Posted May 16, 2006 Share Posted May 16, 2006 The Blowzilla, I think is what its called. It will fit the GT-40 EFI lower intake and I think its a twin screw type supercharger. Quote Link to comment Share on other sites More sharing options...
s3079893 Posted May 18, 2006 Share Posted May 18, 2006 Yeah they do look sutible, but for $3000USD you could probably do your twin turbo setup cheaper Quote Link to comment Share on other sites More sharing options...
Z24O Posted May 28, 2006 Author Share Posted May 28, 2006 blowzilla....is that the kenne bell s/c? if so have heard they are good but pricey i have got a twin GRA 400 carbies and twin B2 converters,one of my concerns is if the single gas outlet from the tank will supply enough fuel to support 500hp+ my other dilemma is whether i need to go EMS to manage the timing....i have a spare wolf 3D but was hoping to keep things simple if possible,possibly get the dizzy regraphed? any comments/ideas welcomed paul Quote Link to comment Share on other sites More sharing options...
s3079893 Posted May 28, 2006 Share Posted May 28, 2006 by twin GRA carbies, do u mean gas research? how much do thoes this retail for? Quote Link to comment Share on other sites More sharing options...
Z24O Posted June 2, 2006 Author Share Posted June 2, 2006 by twin GRA carbies, do u mean gas research? how much do thoes this retail for? g'day s30 yes they are gas research australia carbies......got the entire set up for $700 off an xf ute (250c.i turbo running 11's) i already have a boss 302(not windsor/cleveland) and older steel cased model supra 5 speed in the car, and have the 302 windsor(previously single turbo) and new model supra 5 speed waiting in the wings i am going auto so will be getting rid of the manual i am very impressed with the strength of the supra gearboxes,even the old model one is as good as new despite several diffs giving up the ghost(courtesy of one of previous owners) they both fit in the existing trans tunnel how far you got with your conversion? will it be street legal in victoria? what are you doing for brake upgrade?i've got valiant alloy calipers and ventilated discs up front with r31 skyline discs on rear on my rb30t 240z and i have vt commodore discs/calipers up front on the v8 240 what are you doing for a diff?i am going lsd r200 on the v8....not sure whether quaife/viscous/clsd....probably the former for strength and low maintenance pic of my boss 302 240z below paul Quote Link to comment Share on other sites More sharing options...
s3079893 Posted June 8, 2006 Share Posted June 8, 2006 Hey mate Currently ive got the engine mounted and tranny mounted but i still have to build the motor. Im planning on going with afr heads and im aiming at 400bhp. im also useing a ba xr8 5speed. It will be street legal. I havent given much thought yet about what im going to do with the suspension or brakes yet. I have a 5week holiday coming up and hopefully i can get alot of work done over this winter break. btw: your car looks awesome have you got more pics? -how many zeds do you have, whats the set up like on your rb30 zed? -Have you had any problems running the lpg with a manual box (backfireing etc)? Cheers Quote Link to comment Share on other sites More sharing options...
Z24O Posted June 8, 2006 Author Share Posted June 8, 2006 Hey mate Currently ive got the engine mounted and tranny mounted but i still have to build the motor. Im planning on going with afr heads and im aiming at 400bhp. im also useing a ba xr8 5speed. It will be street legal. I havent given much thought yet about what im going to do with the suspension or brakes yet. I have a 5week holiday coming up and hopefully i can get alot of work done over this winter break. btw: your car looks awesome have you got more pics? -how many zeds do you have' date=' whats the set up like on your rb30 zed? -Have you had any problems running the lpg with a manual box (backfireing etc)? Cheers[/quote'] i've got 3x240z silver one's got the boss n/a 302 and celica steel case 5 speed currently.....i've got the 302 turbo to go in(bought it off a guy that had it in a 260 2+2 with a single turbo on it....i've got a couple of bb turbos off the rb25 skylines as well as the twin gra gas set up)it's got the latest supra 5 speed behind it but i'm going auto(probably AOD) black ones got an rb30et...wolf 3d,fmic,T3,bosch 044,etc....with the vl turbo 5 speed....also got a strengthened jatco and high stall to go in....i'm over manuals,you are reaching for gears too quickly when it's on boost the other one is standard but needs a resto or an injection of horsepower!! any increase in horsepower needs better brakes,mainly front(i have used vented dba rotors ala valiant redrilled for datsun 4 stud with alloy calipers,as well as vt commodore with redrilled calipers/discs on the silver one....need 15"wheels i have r31 skyline discs on the back mainly in case i sheer a stub axle so the wheel doesn't fly off!! i'm in the process of putting an r200 quaife lsd behind the V8....haven't decided on a ratio yet also looking at stiffening the chassis on that car....not sure which way to go there yet....ANYONE GOT ANY SUGGESTIONS? send me your email addy and i'll send you some pics regards paul trying to decide whether to get a nissan r32 gtr and sell my rb30et z atm?? also just bought a mexico short block in case the turbo one grenades over 500hp,lol Quote Link to comment Share on other sites More sharing options...
s3079893 Posted June 9, 2006 Share Posted June 9, 2006 sounds like you have some awesome cars lying around. my email is s3079893@student.rmit.edu.au . btw a well designed rollcage will probably stiffen the chassis up the best, and does not require an engineering certificate as long as you keep within the requiements they put out. Quote Link to comment Share on other sites More sharing options...
turbokid Posted June 12, 2006 Share Posted June 12, 2006 i've got 3x240zsilver one's got the boss n/a 302 and celica steel case 5 speed currently..... hello, i was wondering how you bolted the celica trans to the 302? is there a company that makes the proper bell housing? i was looking into the supra r154 trans behind a 302/5.0 injected any info would be great thanks! Quote Link to comment Share on other sites More sharing options...
Z24O Posted June 12, 2006 Author Share Posted June 12, 2006 hi the guy i got the motor off bought the bellhousing from the states at a cost of $1500!!!,custom HD clutch was another $600,and the box (r154)was new from japan and was $1500 with shifter......the whole lot has done less than 1000km i am selling the lot for $2500 in australia if anyones interested not sure about the celica box/bellhousing,it was in the car when i got it as i mentioned this box has taken some real punishment since mid 80's and still drives like new....a testimony to the strength of toyota gearboxes,the r154 i'd imagine would be even stronger with ratios to suit Z/v8 regards paul hello' date='i was wondering how you bolted the celica trans to the 302? is there a company that makes the proper bell housing? i was looking into the supra r154 trans behind a 302/5.0 injected any info would be great thanks![/quote'] Quote Link to comment Share on other sites More sharing options...
andy mason Posted June 23, 2006 Share Posted June 23, 2006 how about an Eaton 112 siting in Utah for somwhere around five hundred got it don't need it running a 90cid Eaton Quote Link to comment Share on other sites More sharing options...
turbokid Posted June 23, 2006 Share Posted June 23, 2006 another utah guy... cool. by the way guys i found a place that makes adapters for the toyota transmissions to the ford 302 http://www.northwestoffroad.com/parts/manualadapters.html Quote Link to comment Share on other sites More sharing options...
Z24O Posted June 23, 2006 Author Share Posted June 23, 2006 how about an Eaton 112 siting in Utah for somwhere around five hundred got it don't need it running a 90cid Eaton thanks andy considered this but the manifold and distributor position pose some questions.............anyone done it? Quote Link to comment Share on other sites More sharing options...
