DAT240Z Posted May 3, 2006 Share Posted May 3, 2006 I looked in the map sharing sticky but did not find what I was looking for. I would like to find someone with a set up like my (370cc injectors) or close to my that would like to share their maps with me. This is what I'm running STOCK N42 BLOCK N42 HEAD STOCK TURBO T/3 DIS. FOR A 83 TURBO 370CC. INJECTORS 60MM TB supra intercooler megasqurit 3.0 relay board LC-1 wideband 02 3"ext. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted May 3, 2006 Share Posted May 3, 2006 What version of MSnS_Extra code are you running so you know if someone elses code will be able to load into your system? Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted May 3, 2006 Share Posted May 3, 2006 sounds like proxlamus's setup ...with the 300zx watercooled turbo. -Ed Quote Link to comment Share on other sites More sharing options...
DAT240Z Posted May 3, 2006 Author Share Posted May 3, 2006 Brian I looked at my receirt from DYI all is said ids MSNS-E FIRMWEAR loaded. Would this what you are talking about, if not if there a way to find out when I plug in the laptop, or do I have to E-mail Jerry at DYI. Thanks Quote Link to comment Share on other sites More sharing options...
mobythevan Posted May 4, 2006 Share Posted May 4, 2006 I would email Jerry jsut to be sure, it should have something like MSnS_Extra024s13 But newer code has been released so you never know. Quote Link to comment Share on other sites More sharing options...
DAT240Z Posted May 4, 2006 Author Share Posted May 4, 2006 My code is MSNS-E 024s9 Quote Link to comment Share on other sites More sharing options...
Curtis240 Posted May 7, 2006 Share Posted May 7, 2006 I am also looking for a base map for my MS-II with flyback board. This is for a SCCA BSP Z car. I am installing TWM 45mm ITBs on a Cannon manifold with an AEM UEGO wideband O2 sensor. L2.8 bored 40 over, blueprinted, balanced stock cam Clifford 6 to 2 header 2.5" exhaust with Flowmaster Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted May 7, 2006 Share Posted May 7, 2006 I am also looking for a base map for my MS-II with flyback board. This is for a SCCA BSP Z car. I am installing TWM 45mm ITBs on a Cannon manifold with an AEM UEGO wideband O2 sensor. L2.8 bored 40 over' date=' blueprinted, balanced stock cam Clifford 6 to 2 header 2.5" exhaust with Flowmaster[/quote'] this is more like my setup. Except i'm running a race cam/shaved head, and stock bore. I'll post my MSQ back up here once i get it going again. -Ed Quote Link to comment Share on other sites More sharing options...
