burntz Posted May 18, 2006 Share Posted May 18, 2006 I want to place my MSD 6AL in the passenger compartment behind the passenger seat. Will this effect it's performance? I'm planning on using a larger guage wire than what's provided with the unit to connect to the coil and the dizzy. What do you guys think? Quote Link to comment Share on other sites More sharing options...
JaysZ Posted May 18, 2006 Share Posted May 18, 2006 i've seen plenty of boxes located inside, i don't see how it could be a problem but then again, i don't know if they have other provisions in place to boost voltage to the coil/dizzy either. i doubt that one is even necessary.. Quote Link to comment Share on other sites More sharing options...
Mike C Posted May 19, 2006 Share Posted May 19, 2006 You want to extend the big red power wire as little as possible on an MSD box per their instructions. If your battery is still in the engine compartment, under the dash on the passenger footwell would be great, but behind the seat a little far IMO. If you do lengthen it, read for minimum wire sizes (I think 10ga) and ground the MSD wire to the chassis and I would also run another ground from the attachment point of the MS's ground to the battery or engine block. Quote Link to comment Share on other sites More sharing options...
