Pics and short reving clip of New Z
SR240Z
Car: 1972 240Z w/ widebody MSA Street flares
ENGINE/DRIVETRAIN:
`L28 Block with 240z forged rods and KA24 Forged Pistons (3.0 Non Stroker)
`5 Speed tranny
`Fidanza aluminum flywheel
`Centerforce DF Clutch
`R190 Nismo 4.44 LSD
`6-2-1 Header w/ Full dual exhaust
`Triple 40mm Mikunis and manifold
`Ported and polished P90 Head
`Schneider Race cam
`Mallory Electronic ignition (7200rpm cutoff)
`Aluminum radiator with electric fan
`Holley Fuel Pump
`Fuel Surge Tank setup
`15 Gallon Fuel Cell
INTERIOR:
`Cobra Imola Bucket seat
`5pt Harnesses
`Grant Steering Wheel
`Autometer Tachometer
`Wilwood brake bias control and line lock
`Autometer 4pt Roll bar w/ harness bar (For Sale)
SUSPENSION/BRAKES:
`Arizona ZCar Monotube 15way adjustable coilovers (250F/250R)
`Arizona ZCar 4 wheel camber plates
`Arizona ZCar 4-wheel Wilwood 4 piston Brake setup
`Suspension Techniques rear sway bar
`Full Polyurethane Bushings
`MSA Modified front strut bar
WHEELS/TIRES:
`CCW 17x9 front and 17x10 Rear
`Kumho Victoracer V700
`255/45/17 (F) and 275/40/17 ®
dsc003545fg.th.jpgdsc003563ec.th.jpg dsc003575uv.th.jpg dsc003581zk.th.jpg dsc003593nn.th.jpg dsc013973ks.th.jpg
Video clip: http://media.putfile.com/L28-30-Triple-Mikuni-Revs
I see there is a heat shield of some kind under the carbs, can you give me some info on how you made that. I'm building an L28 w/triple webers, I know the header will pour heat into them and am trying to figure a way around that, I was thinking a heat blanket or sleeves, but prefer a metal shield to try to separate the hot air from the intake charge.
Thanks,
Grant
Quench...
If the piston(assum it is not dished) is very close(1mm) to the flat pad in the combustion chamber at TDC, the air/fuel mix is squished into the flame to produce a faster burn. It helps increase hp and reduce detonation. But on a L series head, the quench pad is not that big so not as effective as in a SBC that has a bigger quench pad.
Quench...
If the piston(assum it is not dished) is very close(1mm) to the flat pad in the combustion chamber at TDC' date=' the air/fuel mix is squished into the flame to produce a faster burn. It helps increase hp and reduce detonation. But on a L series head, the quench pad is not that big so not as effective as in a SBC that has a bigger quench pad.[/quote']
gotcha, thanks for clearing that up
Ive said it before and will say it again, there is nothing like the sound of six throttles opening up on a Z, to me that is the greates sound ever.
I love the induction sound of triples, sounds and looks great!!
:2thumbs:
