SR240Z Posted May 20, 2006 Share Posted May 20, 2006 Car: 1972 240Z w/ widebody MSA Street flares ENGINE/DRIVETRAIN: `L28 Block with 240z forged rods and KA24 Forged Pistons (3.0 Non Stroker) `5 Speed tranny `Fidanza aluminum flywheel `Centerforce DF Clutch `R190 Nismo 4.44 LSD `6-2-1 Header w/ Full dual exhaust `Triple 40mm Mikunis and manifold `Ported and polished P90 Head `Schneider Race cam `Mallory Electronic ignition (7200rpm cutoff) `Aluminum radiator with electric fan `Holley Fuel Pump `Fuel Surge Tank setup `15 Gallon Fuel Cell INTERIOR: `Cobra Imola Bucket seat `5pt Harnesses `Grant Steering Wheel `Autometer Tachometer `Wilwood brake bias control and line lock `Autometer 4pt Roll bar w/ harness bar (For Sale) SUSPENSION/BRAKES: `Arizona ZCar Monotube 15way adjustable coilovers (250F/250R) `Arizona ZCar 4 wheel camber plates `Arizona ZCar 4-wheel Wilwood 4 piston Brake setup `Suspension Techniques rear sway bar `Full Polyurethane Bushings `MSA Modified front strut bar WHEELS/TIRES: `CCW 17x9 front and 17x10 Rear `Kumho Victoracer V700 `255/45/17 (F) and 275/40/17 ® Video clip: http://media.putfile.com/L28-30-Triple-Mikuni-Revs Quote Link to comment Share on other sites More sharing options...
Twentyfourouncer Posted May 20, 2006 Share Posted May 20, 2006 Beautiful! Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted May 20, 2006 Share Posted May 20, 2006 like i expected to see a crappy car from you Alex! Quote Link to comment Share on other sites More sharing options...
oinojo Posted May 20, 2006 Share Posted May 20, 2006 so you finally got it together eh... you owe me a ride in that thing... Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 21, 2006 Author Share Posted May 21, 2006 here i got the short video clip loaded onto photobucket, should be better http://s52.photobucket.com/albums/g9/SR240Z/?action=view¤t=MOV00360.flv Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted May 22, 2006 Share Posted May 22, 2006 awsome dude!! Love it!! no turbo this time??? Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 22, 2006 Author Share Posted May 22, 2006 nope, no turbo for this z. Going to stay NA for a while, if i need turbo ill jump in the silver car Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted May 22, 2006 Share Posted May 22, 2006 From the list of parts, looks like it's not getting a lot of quench? Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 22, 2006 Author Share Posted May 22, 2006 From the list of parts, looks like it's not getting a lot of quench? what do you mean by that? Quote Link to comment Share on other sites More sharing options...
Workinprogress Posted May 22, 2006 Share Posted May 22, 2006 I see there is a heat shield of some kind under the carbs, can you give me some info on how you made that. I'm building an L28 w/triple webers, I know the header will pour heat into them and am trying to figure a way around that, I was thinking a heat blanket or sleeves, but prefer a metal shield to try to separate the hot air from the intake charge. Thanks, Grant Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 22, 2006 Author Share Posted May 22, 2006 i will take better shots of the shield tomorrow and post them up, or ill send you a PM with the pictures Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted May 23, 2006 Share Posted May 23, 2006 Quench... If the piston(assum it is not dished) is very close(1mm) to the flat pad in the combustion chamber at TDC, the air/fuel mix is squished into the flame to produce a faster burn. It helps increase hp and reduce detonation. But on a L series head, the quench pad is not that big so not as effective as in a SBC that has a bigger quench pad. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 23, 2006 Author Share Posted May 23, 2006 Quench...If the piston(assum it is not dished) is very close(1mm) to the flat pad in the combustion chamber at TDC' date=' the air/fuel mix is squished into the flame to produce a faster burn. It helps increase hp and reduce detonation. But on a L series head, the quench pad is not that big so not as effective as in a SBC that has a bigger quench pad.[/quote'] gotcha, thanks for clearing that up Quote Link to comment Share on other sites More sharing options...
EZ-E Posted May 23, 2006 Share Posted May 23, 2006 Ive said it before and will say it again, there is nothing like the sound of six throttles opening up on a Z, to me that is the greates sound ever. I love the induction sound of triples, sounds and looks great!! Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 30, 2006 Share Posted May 30, 2006 Video clip: [url']http://media.putfile.com/L28-30-Triple-Mikuni-Revs[/url] Carbs need a little tuning eh? Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 30, 2006 Author Share Posted May 30, 2006 nah dont think so, the car runs great and gets pretty good mileage just cruising on fwy Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 30, 2006 Share Posted May 30, 2006 nah dont think so, the car runs great and gets pretty good mileage just cruising on fwy Doesn't sound as peppy as it should with your hand on the throttle like that.... just saying, they sounded like my out of sync tripples. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 30, 2006 Author Share Posted May 30, 2006 it might sound like em, but it definitely does not run like your car did when it was out of sync Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 30, 2006 Share Posted May 30, 2006 it might sound like em, but it definitely does not run like your car did when it was out of sync That's because my timing was off by what, 15 degrees and I couldn't figure out why... uh yeaah. Quote Link to comment Share on other sites More sharing options...
olie05 Posted May 31, 2006 Share Posted May 31, 2006 I like the radiator mount. with proper ducting (and maybe an opening in the hood) it could provide some downforce at speed. Quote Link to comment Share on other sites More sharing options...
