Administrators SuperDan Posted May 31, 2006 Administrators Share Posted May 31, 2006 is stuck real good. It's supposed to just pull right off by hand right? This sucker is seized on real good and a regular claw type pullers cannot access it .... let me guess "Nissan special tool # blah blah blah" Quote Link to comment Share on other sites More sharing options...
z_cars_rule Posted June 1, 2006 Share Posted June 1, 2006 i used a steering wheel, you will notice 2 (i think) small holes in the pulley, they are threaded, so all i did was find to bolts that fit in there (had some spare from my Z bolts bin that were perfect). i screwed the bolts in about 1cm, then on the other end i put a steering wheel and some washers so that i could use it as a handle to pull it off. a little stiff but it will come off. Quote Link to comment Share on other sites More sharing options...
Administrators SuperDan Posted June 1, 2006 Author Administrators Share Posted June 1, 2006 i used a steering wheel, you will notice 2 (i think) small holes in the pulley, they are threaded, so all i did was find to bolts that fit in there (had some spare from my Z bolts bin that were perfect). i screwed the bolts in about 1cm, then on the other end i put a steering wheel and some washers so that i could use it as a handle to pull it off. a little stiff but it will come off. Not the pulley, the gear. Quote Link to comment Share on other sites More sharing options...
cheftrd Posted June 1, 2006 Share Posted June 1, 2006 If they're really tight, I drill two holes and tap to 6mm X 1.25 and use a puller. Quote Link to comment Share on other sites More sharing options...
Administrators SuperDan Posted June 1, 2006 Author Administrators Share Posted June 1, 2006 If they're really tight, I drill two holes and tap to 6mm X 1.25 and use a puller. Thanks Matt, I was wondering if that was going to be my only option at this point Anyone have part #'s for the gear and the washer/belt guide behind it, I pretty much destroyed that a few days ago. Quote Link to comment Share on other sites More sharing options...
mjfawke Posted June 9, 2006 Share Posted June 9, 2006 Common problem - the drill/tap/pull is the common solution.... followed by oxy torch and more of the same. Friend of mine went through this recently - I'll ask him what the detailed options were. Quote Link to comment Share on other sites More sharing options...
