BLOZ UP Posted June 6, 2006 Share Posted June 6, 2006 when the fuel pump's dead. We were megasquirting a miata, and we had it running for a minute or two. Once it warmed up we had to turn it off and wire in fan control. After that it would only start and die, every time. we put gas in it, no go. later, the guy shorted some circuit in his stock AFM (he stock ECU was removed, though), and the fuel pump started working... Now my friend is convinced that the manifold vacuum was somehow sucking in fuel from the injectors... I told him that's impossible, there's no way there's enough vacuum to suck fuel passed the injectors that are only open for 5 ms, even less to pull the fuel passed a dead fuel pump along with that... Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 6, 2006 Share Posted June 6, 2006 I met a gal that could get that accomplished once. But other than that, you are correct, the vacuum in the intake, assumes engine is running, will not suck fuel through the fuel system. Quote Link to comment Share on other sites More sharing options...
alexideways Posted June 6, 2006 Share Posted June 6, 2006 Tell me I'm right when I told my friend that an EFI car can't "suck" fuel... That is for sure, this ain't no carbs. met a gal that could get that accomplished once. HAHAHAHAHAHAHAHAHA, tears, LOL. Quote Link to comment Share on other sites More sharing options...
