Guest onewickeddatsun Posted June 13, 2006 Share Posted June 13, 2006 im close to being done with my sbc...swap where i came to a stop because i cant use my manual fuel pump...i was just wondering wat have u guys done and if u guys can shoot me some ideas of wat i can use...i was thinking about a fuel cell?... Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted June 13, 2006 Share Posted June 13, 2006 I think reading through this will help. Especially item #2 http://forums.hybridz.org/announcement.php?f=58&a=2 Quote Link to comment Share on other sites More sharing options...
Bartman Posted June 13, 2006 Share Posted June 13, 2006 Search for "electric fuel pump", I think that's what most people use. You can still use your stock tank if you want. Welcome to HybridZ! Quote Link to comment Share on other sites More sharing options...
280zwitha383 Posted June 14, 2006 Share Posted June 14, 2006 put the engine in a ZX Quote Link to comment Share on other sites More sharing options...
JustChou Posted June 14, 2006 Share Posted June 14, 2006 First, I removed the mechanical fuel pump from the SBC. Then, I bolted a Mr. Gasket blockoff plate in its place. I replaced it with a Holley in-line fuel pump, the "blue" model (which comes with an adjustable pressure regulator). I mounted it near the tank, near the stock location. Quote Link to comment Share on other sites More sharing options...
Guest onewickeddatsun Posted June 15, 2006 Share Posted June 15, 2006 First' date=' I removed the mechanical fuel pump from the SBC. Then, I bolted a Mr. Gasket blockoff plate in its place. I replaced it with a Holley in-line fuel pump, the "blue" model (which comes with an adjustable pressure regulator). I mounted it near the tank, near the stock location.[/quote'] Thankz...i will check on that one Quote Link to comment Share on other sites More sharing options...
