15*8
Guest 280ss1976
Guest 280ss1976
hi alll i did my search but cant find a definete answer i want to put 15*8 weld drag lites on my 1976 280z and cant find a offset that in known to work i see alot of guesses but tryin to find a definte number on the back spacing correct me if i am wrong but the factory is 14*6 3.5 backspacing and truly dont understand the size upgrade to off set off the stock springs later to cahnge to coil overs or a stiffer spring setup i kick alot of torque for a street z around 540 hp and about 600lbs of torque yes i have snap the half shafts several times but that another story but if u can help me with the offset i wann run 15*3.5 fronts and 15*8 int he back
Factory wheel size for 280's was 5J-14 with +15mm offset. That would put stock backspacing somewhere in the neighborhood of 4", probably slightly less.
I haven't done it myself, but the consensus seems to be that you can fit 15x8 with 0 offset on a stock suspended 280z.
