Guest 280ss1976 Posted July 11, 2006 Share Posted July 11, 2006 hi alll i did my search but cant find a definete answer i want to put 15*8 weld drag lites on my 1976 280z and cant find a offset that in known to work i see alot of guesses but tryin to find a definte number on the back spacing correct me if i am wrong but the factory is 14*6 3.5 backspacing and truly dont understand the size upgrade to off set off the stock springs later to cahnge to coil overs or a stiffer spring setup i kick alot of torque for a street z around 540 hp and about 600lbs of torque yes i have snap the half shafts several times but that another story but if u can help me with the offset i wann run 15*3.5 fronts and 15*8 int he back Quote Link to comment Share on other sites More sharing options...
nullbound Posted July 11, 2006 Share Posted July 11, 2006 I'm using 15x8 on the rear with 4.5" backspacing. My fronts are 15x6 with 3.5" backspacing. Quote Link to comment Share on other sites More sharing options...
pete280z Posted July 11, 2006 Share Posted July 11, 2006 Factory wheel size for 280's was 5J-14 with +15mm offset. That would put stock backspacing somewhere in the neighborhood of 4", probably slightly less. I haven't done it myself, but the consensus seems to be that you can fit 15x8 with 0 offset on a stock suspended 280z. Quote Link to comment Share on other sites More sharing options...
johnc Posted July 11, 2006 Share Posted July 11, 2006 280ss1976 - Please use punctuation and capitalization in your posts. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 11, 2006 Share Posted July 11, 2006 Factory wheel size in for 280's was 5J-14 with +15mm offset. That would put the stock 280Z backspace around 3 5/8" Quote Link to comment Share on other sites More sharing options...
pete280z Posted July 11, 2006 Share Posted July 11, 2006 That would put the stock 280Z backspace around 3 5/8" Good catch. My 76 FSM notes the offset as "15mm (0.95 in) offset." I used 0.95" rather than converting for myself. I knew that didn't sound right... Quote Link to comment Share on other sites More sharing options...
