How does a cam change compression readings
Bernardd
I have a custom elgin cam. I did a compression test and came out with 105 across all the cylinders. Last year with a stock cam I had 130's with different values across the cylinders. The engine pulls 14in of vac at idle where last year it pulled 18 or so. I bought the head/cam combo used and the previous owner says the vacuum on his engine was very similar. Thoughts???
Bernard
Isn't a performance cams job to get more fuel and air into the cylinder?
That being the case, more fuel and air into the original cylinder would mean that at top dead center we have compressed more volume into the same space resulting in greater compression readings. Right?
No it's a common misconception, you lose compression during the valve overlap which loses some of that extra air/fuel charge it's pulling in. Really you just flow better so it's easier for the cylinder to pull that air/fuel in, not pull in more. Less power lost in pulling it in brings more power by lack of strain.
