johnc Posted July 24, 2006 Share Posted July 24, 2006 I'm going to update information about my 2006 base model 350Z in this thread as I develop the chassis. CORNER WEIGHTS 7-12-2006 - 35 psi tire pressures, 40 lbs of fuel, no spare, no jack, no tools, no modifications. Without Driver Total: 3,217 lbs. Front: 1,792 lbs. - 55.7% Rear: 1,425 lbs. - 44.3% Left: 1,583 lbs. - 49.2% Right: 1,634 lbs.- 50.8% Cross (RF/LR): 1,598 lbs. - 49.7% LF: 889 lbs. RF: 903 lbs. LR: 694 lbs. RR: 730 lbs. With Driver Total: 3,432 lbs. Front: 1,890 lbs. - 55.1% Rear: 1,542 lbs. - 44.9% Left: 1,741 lbs. - 50.7% Right: 1,691 lbs.- 49.3% Cross (RF/LR): 1,697 lbs. - 49.5% LF: 966 lbs. RF: 924 lbs. LR: 775 lbs. RR: 767 lbs. ALIGNMENT These are the factory settings as delivered. Front Camber LF: 1.0- Camber RF: 1.0- Caster LF: 9+ SAI: 6.0 Caster RF: 9.2+ SAI: 6.2 Total Toe: 1/32" in Rear Camber LR: 1.1- Camber RR: 1.1- Total Toe: 1/16" in Quote Link to comment Share on other sites More sharing options...
JMortensen Posted July 24, 2006 Share Posted July 24, 2006 Wow. Thats a ton of caster and a lot of weight in front. Sounds like a project, and it ought to be fun to be able to compare later and see where everything ends up. Quote Link to comment Share on other sites More sharing options...
johnc Posted July 24, 2006 Author Share Posted July 24, 2006 The amount of caster makes static camber less of a concern, which is nice because there is no camber adjustment. About the best I can do while retainining the stock suspension arms and upright is offset bushings. I'm not very concerned about the forward weight bias because the cross weights are good. I should be able to get more weight in the back once I can start adjusting the ride height and move things around a bit. I really, really want do build a custom Compression Rod (arm) and Transverse Link (LCA) in front. I should be able to do a lot of things with the front camber and roll center. Quote Link to comment Share on other sites More sharing options...
