Guest Mike Posted August 4, 2006 Share Posted August 4, 2006 Has anyone tried the Accel 375+ ignition system? What do you think of it? Here's a link (PDF) on page 5... http://go.mrgasket.com/pdf/digital_ignsys.pdf Quote Link to comment Share on other sites More sharing options...
260DET Posted August 10, 2006 Share Posted August 10, 2006 It may help if you do a link to a site featuring that ignition, just a suggestion. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted August 10, 2006 Share Posted August 10, 2006 It may help if you do a link to a site featuring that ignition, just a suggestion. I'll edit my post and try that. Thanks!! Quote Link to comment Share on other sites More sharing options...
260DET Posted August 13, 2006 Share Posted August 13, 2006 Not much response eh The only thing I know is that the Crane Hi systems have a good reputation. A Hi 6 would be my choice for a high performance Nissan 6 that has a distributor. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted August 13, 2006 Share Posted August 13, 2006 Not much response eh The only thing I know is that the Crane Hi systems have a good reputation. A Hi 6 would be my choice for a high performance Nissan 6 that has a distributor. Howdy 260DET, No, not much response to this post. Thank you for taking pitty:biggrin: Thank you too for the Hi 6 vote. I'm running a 350 SBC... I'm estimating 350HP/350Torque (when running right). This one currently has an older (4 plug) HEI dizzy. I've been having some ignition problems, hence my interest in a new system. Until I make a decision and can go all-out, I've simply replaced all the exterior timing components... cap, rotor, module, condenser, wires, and plugs. Although this seemed to help just a bit, the major problems remain... rough idle, missing badly on at least one or two cylinders (not random), backfiring after revving the motor. It threw a belt the other day. On inspection, I see that the water pump pully is just barely wobbling and the alternator is mounted slightly too far forward. These would obviously cause the belt to throw, but... I wonder if the shock of throwing the belt could have caused the timing chain to slip. Maybe if it was already faulty? Does anyone know? Quote Link to comment Share on other sites More sharing options...
