Dayz Posted August 7, 2006 Share Posted August 7, 2006 Hi guys, I am cleaning up the engine bay. I welded all the holes, will run my wiring harness in the upper body frame and...I am now re-routing my fuel and brake lines. If I get an electric fuel pump instead of the mechanical one, I will be able to eliminate some fuel lines in the engine bay. -Is is a good idea? -Is an electric fuel pump as reliable as a mechanical one? -What kind of pump should I get? If you have pictures of that change post them please. Thanks Dayz Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted August 7, 2006 Share Posted August 7, 2006 After looking at some of your old posts which car are you talking about and are you doing a restoration or modifing one with a engine swap??? LARRY Quote Link to comment Share on other sites More sharing options...
Dayz Posted August 7, 2006 Author Share Posted August 7, 2006 Sorry Cozy, This is a restoration. My racing project is on the side at the moment. The engine will be completely stock. Thanks Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted August 7, 2006 Share Posted August 7, 2006 If your engine will be stock I would use the mechanical fuel pump, no need to mess with the electric one. John Quote Link to comment Share on other sites More sharing options...
flames_187 Posted August 8, 2006 Share Posted August 8, 2006 from what i heard..the mech. pumps are decent and strong...my car sat for 2 years and the feul pump was the least of my problems...from what i can tell Quote Link to comment Share on other sites More sharing options...
2126 Posted August 9, 2006 Share Posted August 9, 2006 Dayz, Electric fuel pumps are just fine, plus you will free up a little HP that a mechanical pump requires to operate. My only recommendation is to get a gear driven pump as opposed to a diaphram type pump.....the gear type pump design is less noisey!!! Quote Link to comment Share on other sites More sharing options...
flames_187 Posted August 22, 2006 Share Posted August 22, 2006 flames_187 said: from what i heard..the mech. pumps are decent and strong...my car sat for 2 years and the feul pump was the least of my problems...from what i can tell well i take that back...i must have the only faulty mech. fuel pump:icon56: ...some people run both for protection...if one fails the other covers the end. Quote Link to comment Share on other sites More sharing options...
