Car won't rev past 4k? Now running msd
Thumper
I have had a problem with the car reving past a certain rpms. I just installed a msd 6a instead of a hei module. It still does the same thing. I have played with the dwell settings and they do make it better. At 75% it will not rev past 2800 and at 50% it won't rev past 3700. At the higher rpm the car's tachometer will start to drop off but the tach in megatune will not miss a beat so it is getting a good clean signal just not sending one. I have my 1k ohm 1/4watt resistor as a pullup as needed. I am running megasquirt v3.0 with a flyback and a relay board. Any ideas? Thanks
maybe your distributor is not timed right with the crank? Maybe the rotor is sweeping past where you have designated timing, and it is causing that kind of behavior.
unless the car was running fine before and all of a sudden it started acting up.
n/m just read your post and it seems that the spark is cutting out completely.
did you build it yourself? are you sure the vb921 is hooked up correctly? (are you using the vb921 coil driver?)
  Quote
maybe your distributor is not timed right with the crank? Maybe the rotor is sweeping past where you have designated timing' date=' and it is causing that kind of behavior.
did you build it yourself? are you sure the vb921 is hooked up correctly? (are you using the vb921 coil driver?)[/quote']
The coil driver is not installed. I am running the msd to fire the coil. The only option installed is the flyback board. Thanks
I doubt this is your problem, but a few months ago my alternator belt was slipping under load causing a voltage dip and the symptoms you are describing. Of course it was even worse with the headlights on.
Have you tried increasing/decreasing the value of the pullup resistor? At least with the tach input the following applies:
smaller resistance = more sensitive to lower RPM but noisy
larger resistance = less sensitive to lower RPM but less noise at higher RPM
  Quote
I doubt this is your problem' date=' but a few months ago my alternator belt was slipping under load causing a voltage dip and the symptoms you are describing. Of course it was even worse with the headlights on.
larger resistance = less sensitive to lower RPM but less noise at higher RPM[/quote']
That might be the case if this wasn't under no load. This is reving in neutral. Plus the the alternator is brand new is working perfectly verified with a volt meter. Thanks
  Quote
You HAVE to set some kind of dwell setting in MS, though
remember that in the beginning before MSnS_Extra was even available and we were just using Magnus' MSnS code there was no setting for dwell. The HEI modules had to be heatsinked well. Then as Extra code come into play the eventually added selections for 75% and 50%, then finally you could set dwell (cranking, running, minimum). Even with the magnus code my HEI module worked fine, I believe that was at 100%???
Well I figured the problem was between my megasquirt and msd box. So it was either my relay board was messing up the signal or my megasquirt was sending a bad signal. So I bypassed the relay box and wired my white wire from my msd directly to my megasquirt fidle wire and presto its fixed. I truly don't know why it fixed it. Only that it did. I have guesses mostly bad put together of the relay board but don't really care why its fixed just that it is. So fyi if you have these symptoms bypass your relay box. :-)
