crank angle sensor and or ignitor problem i think
Guest donmobile
Guest donmobile
I have a 81 280zx turbo and got it from a guy for 800 bucks!!!!!!!!! car runs great but has had a miss and thought it was just the same old ♥♥♥♥ plugs wires cap. Anyways have put ajustable fuel reg with gauge and bunch of new stuff in the car and car still missing so went to the track and the miss got really bad before the car even got off the trailer it was small at low speeds before and now the car just loses spark like someone is turning the key on and off saw this on a timing light. air flow meter and fuel press and everthing is good but spark is coming in and out new coil too. can someone tell me if this could be crank angle sensor and or ignitor problem because car runs great but then this sparkcomes in and out sometimes and its like almost a short or something. alsoput a timing light on the cars coil wire to see spark coming in and out also could get timing to chage at all no advance or anything when you turn the dissy?
sounds like the ignitor chip, or the wires going to it, are fried.
Guest donmobile
update everyone, I got my flex lite electric fans in today put them in the car and started it up and she run great but as soon as she got to running temp problem started again!!! its like someone is turning the key on and off spark just dies please help
Guest donmobile
update again got coil at junkyard with ignitor from a 84-85 sentra is the same wow hard to find that one out. Anyways doing the same thing still no ideas? Also put intercooler in today but car still runs shitty when hot
Guest donmobile
yes thats what i have and i think that might be the problem because found a ignitor and coil from a 84 sentra that is the same and car does the same thing. any idea how to test it?
Guest donmobile
z31? does that mean 300zx? also can i use none turbo dissy from 280zx i think there points though that wont work right. also i I get dissy from 300zx non turbo will computer work the same with it and do i need to adapt it?
