Guest Andrew240 Posted August 17, 2006 Share Posted August 17, 2006 I'm trying to get a quote on building my stock t3 into a t3/t4 hybrid from a local builder. Is it standard procedure to use just the impeller wheel from a t4, or the entire compressor housing and the impeller wheel? What size comp housing should I be looking at getting? Thanks!! Quote Link to comment Share on other sites More sharing options...
Garrett76Zt Posted August 17, 2006 Share Posted August 17, 2006 Yes, generally the compressor wheel AND housing are replaced. Most of the time the T3 side is the exhaust side and the T4 side is the compressor side. A TO4B housing will not require any spacer and can be made to accomodate up to a 60-1 wheel, so its a good choice for Compressor housings. Quote Link to comment Share on other sites More sharing options...
nismopick Posted August 17, 2006 Share Posted August 17, 2006 I had a local turbo shop rebuild my turbo to be a T3/T4 hybrid... $150 labor, $200 in parts. Quote Link to comment Share on other sites More sharing options...
