240z Stub axle replacement.
zane9000
So I brought my Z into the shop to get a wheel bearing replaced, and it looks like they broke off the threaded end of the stub axle while trying to remove the nut. Neither the shop nor I can find a replacement part, so what I think I will have to do is just head to the junk yard and grab a whole new hub assembly. I know that the stub axle itself is different between the 240z and the 280z, but if I grab the whole hub assembly will that matter? I will have the right companion flange and whatnot, so I assume it should just bolt right in. Or am I thinking this will be too simple?
Thanks,
Warren
That will work. My early 260 had a 240 stub on one side, and a 280 on the other when I got it... don't know for sure if it didn't come that way from the factory, as that was a change over period for alot of the 240/ 280 parts...
Like you said, make sure to get the companion flange, and your good to go...
