jnjdragracing Posted August 21, 2006 Share Posted August 21, 2006 Installed a alternator on our Z-car, Alternator came from a 300zx, 1986 model I think. searched this site and wired it up. Used 8 gauge wire from alt. output to fuse panel where it ties into the battery. Used the brown wire to lamp, black wire to ground. Went to the dragstrip last night. Fully charged battery. Tested it, read 12.97 volts. Cranked up car, read 13.7 volts idleing, reved it up some and read 14.7 volts. Seems like the alt. is working right. Well normally at the drag strip, we can go about three rounds before needing to charge the battery. Last night, we had to charge after the 1st pass. Could the alt., be discharging or shorting out the battery? I would think with it working we could go longer with out charging the battery. I know we draw alot of juice, electric water pump, fan, fuel pump, msd ignition, running lights, brake lights. Anyway cut the alt, belt and disconnected it. Any help please.......... John Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted September 13, 2006 Share Posted September 13, 2006 14.7v charging is too weak. I have a Honda alternator in my Z and it's charging at 15. something volts. You might want to try different alternator or get a hi rated amp one from Zman of washington. GL Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 13, 2006 Share Posted September 13, 2006 There's nothing wrong with 14.7 volts what you need to worry about is how many amps are being put back into the battery vs how many are being pulled while your doing your thing? Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 13, 2006 Author Share Posted September 13, 2006 Thanks, As soon as I get the Engine running right, I will pursue the Alternator again. John Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 13, 2006 Share Posted September 13, 2006 One of the better ones that you can try are out of the 90's model Maxima. I forget which one but, They almost all put out atleast 80 amps. Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 14, 2006 Author Share Posted September 14, 2006 Thanks, I will try it again once I figure out my performance problem. John One of the better ones that you can try are out of the 90's model Maxima. I forget which one but, They almost all put out atleast 80 amps. Quote Link to comment Share on other sites More sharing options...
Alex_V Posted September 17, 2006 Share Posted September 17, 2006 89-94 maximas any of them. 90 and 95 amps I believe. I need to double check that, but thats withing 5-10 amps for either. the 92-94 SE maximas with the DOHC engine have 5 more amps then the other maximas. ~Alex Quote Link to comment Share on other sites More sharing options...
