Alternator question - please help
Installed a alternator on our Z-car, Alternator came from a 300zx, 1986 model I think. searched this site and wired it up. Used 8 gauge wire from alt. output to fuse panel where it ties into the battery. Used the brown wire to lamp, black wire to ground.
Went to the dragstrip last night. Fully charged battery. Tested it, read 12.97 volts. Cranked up car, read 13.7 volts idleing, reved it up some and read 14.7 volts.
Seems like the alt. is working right.
Well normally at the drag strip, we can go about three rounds before needing to charge the battery. Last night, we had to charge after the 1st pass.
Could the alt., be discharging or shorting out the battery?
I would think with it working we could go longer with out charging the battery. I know we draw alot of juice, electric water pump, fan, fuel pump, msd ignition, running lights, brake lights.
Anyway cut the alt, belt and disconnected it.
Any help please..........
John
  • 4 weeks later...
