Owen Posted May 15, 2001 Share Posted May 15, 2001 What is the strongest stub axle that will fit on the rears of a 73 240Z? I heard that the 280Z axles are stronger? Will I need a new companion flange as well? Thanks. Owen Quote Link to comment Share on other sites More sharing options...
Guest scca Posted May 15, 2001 Share Posted May 15, 2001 yes and yes-- 280 is stronger and the flanges are different splines Quote Link to comment Share on other sites More sharing options...
pparaska Posted May 15, 2001 Share Posted May 15, 2001 Like scca-Mike said. And the CV shaft swap can't use the 280ZXTurbo companion flanges for this reason. If you change to the 280Z stub axles, and want to do CVs, you need an adapter like Scottie did a GP of. Quote Link to comment Share on other sites More sharing options...
Owen Posted May 15, 2001 Author Share Posted May 15, 2001 That's what I thought, thanks guys! So I will need to use a flange that mates to the R230 shaft like Curtis is investigating, or to do what Mark did and get adapter plates made... Owen Quote Link to comment Share on other sites More sharing options...
Owen Posted May 17, 2001 Author Share Posted May 17, 2001 Thanks, if I switch to the 280Z stub axle, will this affect the position of my brakes, calipers, etc.? What year 280Z is the one to get? Any other cars which can be used with the 1st gen Z? Thanks, Owen Quote Link to comment Share on other sites More sharing options...
pparaska Posted May 17, 2001 Share Posted May 17, 2001 Any 280Z will have the correct stub axle. The flange will end up in the same place, so brakes, wheels will be unchanged. Quote Link to comment Share on other sites More sharing options...
johnc Posted May 17, 2001 Share Posted May 17, 2001 The 280Z stub axle has 27 splines on the companion flange end, while the 240Z stub axle has 25 splines. The 280Z stub axle is still available from Nissan new and are a better design than original (better radius on the flange to axle weld). [ May 16, 2001: Message edited by: johnc ] Quote Link to comment Share on other sites More sharing options...
