What is the quickest way to detect LSD in R200?
Z-Noob
Tomorrow I am going to pick up an "R200 LSD" from a gentlemen who said it was original from a 83'zx. Now I have "searched" on the forums and have come to the conclusion that 83' zx were not LSD. My question is, what is the easiest way to determine if the rearend has an LSD unit?
The unit is apart from the automobile. I ws going to attempt to spin the driveshaft by hand while having a friend holding one of the axles and making my determination on what the other axle does. Does this sound logical? Thank!!
Spend a few minutes reading in the drivetrain section, and you'll educate yourself enough to where there shouldn't be any doubt on your part....
I think you should look at pics of what a LSD carrier looks like, then just pull the rear cover off the diff and have a look, if its out of the car.....
Spend a few minutes reading in the drivetrain section' date=' and you'll educate yourself enough to where there shouldn't be any doubt on your part....
I think you should look at pics of what a LSD carrier looks like, then just pull the rear cover off the diff and have a look, if its out of the car.....[/quote']
Me three.
Gaskets are cheap
