Header designs: N/A and Turbo
Alright OTM, I'll play your game: here's my turbo manifold sketch, to no particular scale (but it does look pretty cool)
It's a thumbnail, so click it to make it bigger if you want to check it out. I'll do some measurements tomorrow of my t-4 and the head to strut mount clearance to maybe put some scale on it.
*edit* I just measured from the exhaust flange to the strut tower, and it was just over 13", something like 13.5". It's hard to get an exact measurement because all my manifolding is in place, but it seems like a reasonable amount of space to work with. I'll measure my turbo when I get home.
It seems like there is more space there than I first thought. This is the engine bay I'll be working with:
Alright OTM' date=' I'll play your game: here's my turbo manifold sketch, to no particular scale (but it does look pretty cool)
i would make those two pipes that come off the 2 sets of 3 a bit wider. sort of like a collector, as the current design basically fuses 3 pipes into 1 of the same size, which would be a restriction. if you go for 2/3 or 3/4 the size of the 3 pipes combined, you will probably get good low end, and a nice flowing top end.
