surfsnake2 Posted August 31, 2006 Share Posted August 31, 2006 I was wondering if someone could give me some info on side pipes on the stock inline six, what is the best way to run side pipes? My guess was to weld it to the header where its comes into 2 pipes, and then run off some custom pipes into 90's for the side pipes. But if anyone has actually ever done this and can give some more detailed information on what I need to do that would be great pics would be great also. Also some info on how high they should be mounted to not worry about ground clearance (hitting speed bumps) would be nice Thanks Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted August 31, 2006 Share Posted August 31, 2006 I've never seen a stock Z with sidepipes but can tell you this about speed bumps. There is no magic number for clearance. I have to scout every parking lot and every entrance and exit for their angles. I have 4 1/2 in. clearance and that's the best I could do. This was gained by notching the frame rail. If you swap a V-8 in your car I can give you lots of details and pics.... LARRY Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted August 31, 2006 Share Posted August 31, 2006 well the drivers side is not that hard. I would go over the frame rail and cut out the rocker panel and weld in about a third of a 4" pipe so that you can tuck the pipe in close. Sort of like a Daytona Coupe. Instead of running a huge expensive set of pipes I would get some tubing and some glaspack mufflers and turnouts and make it to fit just right. I'd cut out the bottom front corner of the fender too to get the pipe closer to the body. Quote Link to comment Share on other sites More sharing options...
surfsnake2 Posted September 1, 2006 Author Share Posted September 1, 2006 Well I went ahead and ordered them in, and I will do some work to see how to mount them for ground clearance, these are 3" with a heat shield so im assuming about 3.5" - 4" total. And Cozy could you post me some pics or email them to me of the side pipes on your Z so I can see how you mounted them? And does anyone know about how how the heat shields will get? I have heard that the heat will transfer through the brackets and they will get just as hot, but I went ahead and bought some exhaust wrap for them to wrap the area under the shields. Hopefully it will help some, I would hate to see any burns come from this. Does anyone know how much heat the exhaust wrap will stop? I dont mind if it still makes the heat shields get hot but not hot enough to burn someone badly. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted September 1, 2006 Share Posted September 1, 2006 Here you go .... Good Luck. LARRY Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted September 8, 2006 Share Posted September 8, 2006 Hi Larry, How is the sound with those side pipes? do you mind record a sound clip or video for us? I am in the planning stage how to build my sidepipes for my ls1 daytona coupe project. I have the stock SS C5 headers that I modified to fit into my Z now but I think I will custom build my headers to work with the side pipes. I want to build the headers to come straight out from the block and go thru the fender well above the frame rails. Then make a slight bend toward the back and down to the inlets of the sidepipes. On the driver side I have to move the brake lines and route them some where else. Other than that the passenger side is all open. The other concern I have is how do I reenforce that areas after I cut 2 big holes in the fender well. I have checked and I have plenty of room behind the front wheels for the pipes to come out in that area. I know it will be a lot of work and $$ but I want the sidepipes to tuck away and up high just like the original Daytona coupe. What do you guys think of my ideas? Thanks Vinh Surf, sorry for hi jacking your post. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted September 8, 2006 Share Posted September 8, 2006 LOL... I'm not the one to ask about doing things different or costing $$$. Go for it.... Here's a couple old videos to give you a feel for sidepipe sounds. One is at idle and one was a dyno run. LARRY Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 8, 2006 Share Posted September 8, 2006 Larry what were the dyno numbers, just interested. John Quote LOL... I'm not the one to ask about doing things different or costing $$$. Go for it....Here's a couple old videos to give you a feel for sidepipe sounds. One is at idle and one was a dyno run. LARRY Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted September 8, 2006 Share Posted September 8, 2006 This run is at 10lb boost with iron heads. Let's just say the 195 AFR heads plus a couple other changes like lift, bee hive springs, and roller rockers has improved these numbers shown.... My problem now is wheel spin from a dead stop at WOT. It's a street car so 225-50-15 tires are it but I still like to "spank" them at the light. I've got a raced prepped TH-350 with 2400 stall and a mild cam. I went to AFR heads because you'll notice at 4200 rpm I started to flatten out. That's changed now... Sorry for the thread subject change.. LARRY Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted September 8, 2006 Share Posted September 8, 2006 Not bad larry, It is probably like mine, all from the get go. At wot it is instant power, no lag. My setup 6-71, the harder I turn it the more power I make. Thanks for the info. Quote This run is at 10lb boost with iron heads. Let's just say the 195 AFR heads plus a couple other changes like lift' date=' bee hive springs, and roller rockers has improved these numbers shown.... My problem now is wheel spin from a dead stop at WOT. It's a street car so 225-50-15 tires are it but I still like to "spank" them at the light. I've got a raced prepped TH-350 with 2400 stall and a mild cam. I went to AFR heads because you'll notice at 4200 rpm I started to flatten out. That's changed now... Sorry for the thread subject change.. LARRY[/quote'] Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted September 8, 2006 Share Posted September 8, 2006 My most fun is running against the Mustang "Dyno Queens" who spout their 450+ rear wheel figures at me and I say let's go for a little run...... They end up in my rear veiw mirror not realizing that extra 1000+ lbs they're carrying is in my favor... LARRY Quote Link to comment Share on other sites More sharing options...
surfsnake2 Posted September 13, 2006 Author Share Posted September 13, 2006 PICS! The exhaust wrap on it makes a huge difference, keeps the heat shields very cool so no risk of burns Quote Link to comment Share on other sites More sharing options...
z_cars_rule Posted September 15, 2006 Share Posted September 15, 2006 that looks great, would you mind posting a video or sound clip so i can see what side pipes sound like on an L6. Quote Link to comment Share on other sites More sharing options...
surfsnake2 Posted September 19, 2006 Author Share Posted September 19, 2006 Ok finally got the video and audio. I also got the car appraised at 12.5k yesterday which is quite exciting since I bought it for 3500 ~years ago, nice to see that Ill have some coverage for insurance. Quote Link to comment Share on other sites More sharing options...
kuntry Posted October 9, 2006 Share Posted October 9, 2006 surfsnake2 said: Well I went ahead and ordered them in, and I will do some work to see how to mount them for ground clearance, these are 3" with a heat shield so im assuming about 3.5" - 4" total. And Cozy could you post me some pics or email them to me of the side pipes on your Z so I can see how you mounted them? And does anyone know about how how the heat shields will get? I have heard that the heat will transfer through the brackets and they will get just as hot, but I went ahead and bought some exhaust wrap for them to wrap the area under the shields. Hopefully it will help some, I would hate to see any burns come from this. Does anyone know how much heat the exhaust wrap will stop? I dont mind if it still makes the heat shields get hot but not hot enough to burn someone badly. where did you find 3" pipes? all Ive been able to find is 2" so far. Quote Link to comment Share on other sites More sharing options...
