Modern MotorSports LTD Brakes Question
Hi,
I have some Modern MotorSports Ltd Disk brakes in front and rear with PBR aluminum DOT calipers. I was wondering if anyone knew if the stock brake master cylinder is capible of handling these much bigger calipers? Or do I need to spend more money on a better master cylinder? Thanks. Allen Botimer
Hi , I am using the same setup from Ross, actually I ran it first in prototype to verify the product. Running on a 73 240z with LT1 and six speed. I have the stock brake master cylinder, ( rebuilt ) it works fine! Did have to play with the proportioning valve a bit to dial in the right balance! Some others have also had to select a variety of pads to suit there particular application! get a reccomendation for your application.
