dat240zg Posted September 5, 2006 Share Posted September 5, 2006 Well....kind of a weird thing for you guys. I went to replace the Optispark cap and rotor (The kit that I was putting on was the MSD set for the optispark1) and found that it didn't fit. The shaft that the rotor sits on stuck out too far. I recognize that the shaft sticking out farther is an indicator of the OptiII, but mine is not vented (that I can tell). BTW, the motor is a mid '94 LT1 from the Firehawk. Has anyone run into a mid year optispark that had some of the characteristics of the Opti1 and Opti2? Even Summit was having a hard time matching up the parts. Thoughts anyone? Bueller, Bueller???? Bryan Dat240zg Quote Link to comment Share on other sites More sharing options...
80LS1T Posted September 6, 2006 Share Posted September 6, 2006 Are you talking about the dowl sticking out of the cam? If so, I think you can just tap it in further. I think I remember reading about what the correct depth should be when installing a not factory cam(don't remember where though?). So I would think that installing it a little deeper into the cam would be perfectly safe. Guy Quote Link to comment Share on other sites More sharing options...
dat240zg Posted September 6, 2006 Author Share Posted September 6, 2006 Thanks Guy. I'll head out and see if there is any movement possible. The dowel was sticking out almost a quarter inch farther than the rotor cap would go on. Bryan Quote Link to comment Share on other sites More sharing options...
Bartman Posted September 6, 2006 Share Posted September 6, 2006 Here's a link to a site that has detailed information regarding the opti including pictures. You can see that the vented opti is quite a bit different and requires a different timing cover. As Guy posted, if you have an early opti the cam pin needs to be lower than with a later opti. I did a lot of investigation and wound up upgrading my early opti to a newer vented opti, and I don't think they produced an inbetween model. http://para.noid.org/~muttvette/opti.html Quote Link to comment Share on other sites More sharing options...
